Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
fuel adjustment ??
Old Apr 11, 2008 | 03:25 PM
aidali75's Avatar
Default fuel adjustment ??
hi folks !
i don't know what happened to my audi a4 1.6 automatic year 2000.. ihave checked with the mechanic and was told that the problem was related to the fuel adjustment.. i haven't got any clue at all..
the enginestopped automatically too frequent when i press theaccelerator especially when i stop at the traffic light. it is also stop when the car is going uphill or downhill but this happened quite seldom.. so, i need to drive on the flat land only when the car stop, a battery indicator sign will come out.
anyone out there came accross with this kind of problem ?
really appreciate any helps.
Old Apr 13, 2008 | 07:35 PM
zippy_gg's Avatar
Default RE: fuel adjustment ??
Have tried plugging a VAG to your car t see if there are any error codes? I bet this will help you.
You may also have a weak battery. Do you know when it was last replaced?
Old Apr 15, 2008 | 04:11 PM
aidali75's Avatar
hi zippy !
thanks for your prompt reply.
my battery is new.. maybe should for VAG
Old Apr 22, 2008 | 02:12 AM
khooper's Avatar
I am not sure about it but on some cars the fuel inlet would be at the rear of the tank and the tank being low on fuel could be causing a starving of the fuel pump. Being (facing) downhill the pump would be sucking AIR and starving the injecters.
____________________
Radiator Hose Accessories
Old Jul 20, 2008 | 02:25 AM
Prizmatik's Avatar
The battery sign may come on due to a bad alternator or a bad connection on the alternator. Make sure to inspect the alternator and all connections on it very well. I recently replaced an alternator that had a bad connection and the stud connection to the battery was weak and eventually broke. Hope this helps. Good Luck.
skihigh2299
Oct 11, 2015 05:54 PM
skihigh2299
Sep 25, 2015 12:09 AM
AUDIFIELD
Sep 24, 2009 12:24 PM
Maine Man
Aug 1, 2009 07:26 AM
myownstylett
Jun 23, 2008 12:46 PM
