Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
how to get engine diagnostic codes with no equipment in seconds(free)
Old Jun 28, 2006 | 02:56 PM
R31LLY's Avatar
Member
Default how to get engine diagnostic codes with no equipment in seconds(free)
turn the ignition on
press and hold the re-circulate air button
press the up arrow
let go off all buttons
now select 1 degrees C
then press re-circulate button again
and it will give you a code 00.0 means no errors if you get a code pm and ill tell you what it is
another way to get it up is. . .
start your car then on your climate control panel press and hold in fan down, temp colder and ECON at the same time
you will see a mode sayin 1 degrees C and press recirculate key to enter
each degree c is another option all the way up to 61 and 16 or 17 and the normal speedo ones
Old Jun 28, 2006 | 02:57 PM
techbod's Avatar
Default RE: how to get engine diagnostic codes with no equipment in seconds(free)
aircon system codes only
Old Jun 28, 2006 | 03:01 PM
R31LLY's Avatar
Member
yeh your right sorry i never noticed
Old Jun 28, 2006 | 05:18 PM
techbod's Avatar
any free information is welcome mate and its good to see it here
Old Jun 29, 2006 | 02:31 PM
R31LLY's Avatar
Member
it does tell you your potenciometer reading and all sorts and tempritures from all over the car
my a3 wont change from kph to mph though i have tried both ways to do it its not havin it
Old Dec 24, 2006 | 09:52 PM
tj19855's Avatar
nedd help with code P0341
Old Dec 27, 2006 | 05:40 PM
vellomike's Avatar
I'm showing that to be cam shaft position sensor...hope that helps
Old Jan 4, 2007 | 04:15 PM
mirkocrocop's Avatar
Ok can you say wich number from 1-99 is the outside temperature?
Old Jan 4, 2007 | 05:46 PM
techbod's Avatar
well the actual code is 00779 but if only 2 digits ill have to guess its 79
star_diagnose
Mar 9, 2008 05:30 PM
stardiagnose
Nov 17, 2007 06:05 AM
star_diagnose
Jun 14, 2006 06:37 PM
