how to get engine diagnostic codes with no equipment in seconds(free)
turn the ignition on
press and hold the re-circulate air button
press the up arrow
let go off all buttons
now select 1 degrees C
then press re-circulate button again
and it will give you a code 00.0 means no errors if you get a code pm and ill tell you what it is
another way to get it up is. . .
start your car then on your climate control panel press and hold in fan down, temp colder and ECON at the same time
you will see a mode sayin 1 degrees C and press recirculate key to enter
each degree c is another option all the way up to 61 and 16 or 17 and the normal speedo ones
press the up arrow
it does tell you your potenciometer reading and all sorts and tempritures from all over the car
my a3 wont change from kph to mph though i have tried both ways to do it its not havin it
star_diagnose
Mar 9, 2008 05:30 PM
stardiagnose
Nov 17, 2007 06:05 AM
