Computer & Fuel Systems Talk about the computer, fuel systems and delivery, customization and more.
Need Help!! scanner "linking error" what do I do???
Old Mar 9, 2008 | 10:41 PM
dcarlson01's Avatar
Member
Default Need Help!! scanner "linking error" what do I do???
I have a 2001 A4 Quattro. The car was running just fine yesterday and all of a sudden the CEL came on...... I previously purchased a vag can scanner to aid me in removing any unnecessary CELS. The problem is..... when I try connecting to the obd2 port thr scanner lights up and stays on but when trying to do a scan after a few seconds the words "linking Error"keep coming up. removed the battery terminal to reset the CEL and it worked but for some odd reason the scanner still comes with the "LInking Error"!!!! Anyone know what it may be?? please let me know
Old Apr 13, 2008 | 07:51 PM
zippy_gg's Avatar
Default RE: Need Help!! scanner "linking error" what do I do???
You probably have not configured the software to connect to the proper serial port on your laptop.
You need to go to your Device Manager in Windows and see which port is used (COM1, COM2, COM3, etc... after you installed the USB to Serial driver), then match this in the VAG-COM software and test the connection.
Old Apr 15, 2008 | 11:16 AM
auditurbo381's Avatar
when i got link error my car wasnt recognizing my ECU and neither was vag or the OBD II. i had to get a new ecu... mine got wet. everything looked fine. but link error came up as soon as the car stopped starting. your car running ok?!
Old Nov 14, 2013 | 09:30 AM
4RingBling's Avatar
i have the same issue with my car. it will run fine then all the sudden won't hit 10psi any more. Then after a while it throws a CEL but i can't scan it do to the linking error. WTF!!!!!!!!!
Old Dec 11, 2013 | 08:18 PM
ilikeobd2's Avatar
perhaps the driver is wrong,so read error,what's more,you can find help on our website.
vvdifactory Team
Old Dec 18, 2013 | 10:03 AM
octeobd2's Avatar
may be Software is not configured to connect to your laptop's serial port。
We provide software and test cable connection at greebid
Old Sep 20, 2014 | 07:37 PM
greenmtrider's Avatar
Just had the same trouble with my 08 a4 so a purchased another OBD2 scanner. Now I am able to get my codes and clear all.
dcarlson01
Jun 10, 2016 08:45 PM
4RingBling
Nov 9, 2013 12:16 PM
A8 LOOONG
Feb 9, 2011 02:48 PM
george3.3
Feb 13, 2009 09:14 PM
ilovelagar
Oct 22, 2008 12:37 PM
