DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your ride as told by your fellow members.
Aftermarket Side Marker Install by BoostedA4
Old May 3, 2005 | 08:44 PM
Amanda's Avatar
Default Aftermarket Side Marker Install by BoostedA4
Thanks To BoostedA4 For This Article!!
Tools:
• Thin flathead screwdriver (or something to pry with)
• Rubber glove (or something to cover the pry tool, so not to scratch the paint)
Steps:
1) Pry out the OEM side markers, you will see on the aftermarket ones, there is a tab that clips the marker into place, when taking out the stock marker, push that tab which is also on the stock units in and pry the marker out at the same time.
2) You will see it is connected to power. Pull off the old marker, pull out the old clear bulb.
3) Put the amber bulb back into the socket, put the aftermarket marker over the bulb. Snap back into place. You are done. Do the same for the other side, step back and enjoy.
[IMG]local://upfiles/20/E276797E97364ECC9D25B31F53A18BF2.jpg[/IMG]
[IMG]local://upfiles/20/4C153A1219A143B981805F6D5943EF07.jpg[/IMG]
[IMG]local://upfiles/20/32381684B9D440ABB774B72BBC4323D4.jpg[/IMG]
NOTE: A credit card makes a good tool to release the tabs under the lights.
chefro
Dec 29, 2010 09:40 PM
gabe711
Jun 25, 2008 10:56 PM
pattycakes77
May 18, 2008 09:02 PM
Euro S4
Mar 6, 2007 06:35 PM
ibe3pac
Jan 26, 2006 09:37 PM
