A3 hazard/indicator switch
Old Mar 11, 2013 | 12:37 PM
Rustyone's Avatar
Default A3 hazard/indicator switch
2003 A3 hazard/indicator relay. I need to replace it. OK, I know where it is. I've removed the bezel and get get the three switches to the right out, but I can only get the red triangle light cover off. The thing itself seemed utterly fixed and I'm afraid of busting something if I jemmy it out? (Also, the book says I should disconnect the neg battery lead first? Doesn't that kill the radio etc?) HELP
Old Mar 11, 2013 | 02:15 PM
ilackav8's Avatar
the switch on the dash? its held in by clips (the face plate does come off comparatively easily)
so the switch is held in by some clips on the side. you need a small pick or screw driver to wedge in there and depress one side. the switch comes out fairly easy once you do this.
do a google image search for a little more guidance as to what it actually looks like. good luck!
rezron
Aug 27, 2017 02:59 AM
johneyy57
Nov 24, 2014 09:03 PM
jaredpc
Jul 27, 2010 04:10 PM
holdin16
Mar 1, 2010 01:13 AM
Dj Spiel
Mar 11, 2008 01:17 AM
