A6 1st gear lag
Old Jan 5, 2020 | 03:12 PM
thericb's Avatar
Default A6 1st gear lag
Can someone help me figure this out. I have a 2006 A6. I had the transmission computer replaced and reprogrammed. Since replacing it. It seems to have a lag in first gear only. Like it is starting in second gear but then it is fine. I feel that it is a programming issue as I have had the battery reset a couple times and it will shift fine until the computer modules are all reset. Then it goes into this "limp mode" 1st gear is non existant. In manual mode it says it's in first but there is still a lag. Again after it gets up to 2nd gear speeds it works find and is quick and torquey.
Is there anyone out there that can program or run diagnostics remotely. I know that the dealership will be expensive and I do not want to go that route right now.
Thanks for the help...insight...direction.
Larry Kelly
Nov 16, 2019 07:47 PM
StrongTyer
Jun 2, 2013 05:12 PM
TheDane
Mar 16, 2010 05:00 PM
mattpalmgren
Sep 10, 2008 09:00 PM
