A6 C6 MMI High 2G 3.3.60 – lost Phone, Camera, Steering after GROM swap for CD
Old Jan 20, 2015 | 05:57 PM
mosswald's Avatar
Exclamation A6 C6 MMI High 2G 3.3.60 – lost Phone, Camera, Steering after GROM swap for CD
Hi all, I’m hoping someone can help me understand what went wrong and what I can do to fix this.
I have a 2007 A6, MMI High 2G, version 3.3.60 installed. Recently got the car.
I replaced my factory CD player with a GROM-MST3 device. I had some trouble with powering the device at first, and there was a brief point where the MMI started up for maybe 15 secs then powered down. I also did some reboot/resets (along with a voodoo chant). Then I tightened up the wires/connection from the GROM using their instructions (wires on the CD harness) and the optical cables, I got the GROM to power up per usual and I can play audio with it. I'm pretty sure this installation process/futzing is where I aggravated the Audispirits and may have caused the MMI system to reset or otherwise lost its list of things that are attached.
So, at this point I have FM, GROM (as CD), and Navigation.
But I DON’T HAVE steering wheel controls, rear camera, or telephone. Weird thing – when I press Siri on my phone the telephone shows up on the dash display (so it sort of is still bluetoothing, but I can’t hear or control it). Switching to telephone on the MMI controls says “telephone not installed”.
A little more info: I do not have a VAG-COM, but I did borrow a friends VAG401 device and it gave me some information, which I assume might indicate something:
Electrical systems 1 ---07 head control
Control unit 4f0910732
Part. Interfacebox h43 3360
2 trouble codes :
00003. Control module
01042. control unit not coded
Electrical systems 1 ---19 gateway can
Control unit 4L0910468
Part. J533_gateway h06 0040
Importer number 785
Extra devices 00200
Service station code 02334
COD f5d5de77307a06
2 trouble codes
00384 optical databus closed
02076 media player position 1 - r118
Any pointers in the right direction would be greatly appreciated! Thanks in advance!
hyland
Oct 8, 2007 03:39 PM
dazA6
May 7, 2007 02:35 PM
Condo
Feb 24, 2007 03:47 PM
tip5
Jan 22, 2006 07:56 PM
Peteman187
May 10, 2005 01:48 AM
