abs problem audi a2
Old May 11, 2006 | 07:13 PM
xenos's Avatar
Default abs problem audi a2
hallo from greece.i need help.i have audi a2 and i have a problem with the abs when the speed of the car reech 20km the abs lamp is on i put the computer to chek the abs and the problemis the left frond speed sensor .i replace the senson but it is doing the same thing ihave check the wares and there are ok .can anyone help me ?
Old May 11, 2006 | 07:22 PM
techbod's Avatar
Default RE: abs problem audi a2
what code did you get?? you might have changed the wrong sensor it might be the other side if you get the code I will check for you
Old May 11, 2006 | 07:30 PM
xenos's Avatar
you meen the code of the part [the sensor]or the code of the diagnostic tool result.as fer the part i order it from audi with the serial numper of the car ,i dont think that it is wrong .i think that the problem is from the central unit of the abs ???????????i think because i i have changed the sensor i've chaked the wires i've taken out all the wheel and all the prts behind the wheel [i dont know how to write theme down in english ]behind the while it has a plstic think that the sensor takes the signal and that part is ok
the only think that is left to change the sentral unit
Old May 11, 2006 | 07:45 PM
techbod's Avatar
when you ran the diagnostic you will have been given a 5 digit code on your scanner
00283 front left sensor
00286 front right sensor
00287 rear right
00290 rear left
Old May 11, 2006 | 07:52 PM
xenos's Avatar
thanks i will see it tommorow
Old May 11, 2006 | 08:00 PM
techbod's Avatar
Default RE: abs problem Audi a2
no problem mate if you have any problems ill be here and your command of the English language is quite good
marcoetreni
Oct 12, 2009 03:32 PM
cgroff5686
Apr 7, 2009 09:12 PM
Mikesd1980
Jan 11, 2008 11:11 PM
johnstef
Aug 30, 2006 12:42 PM
audidaft
Feb 23, 2006 01:28 AM
