audi A6 1,8t AEB 99 oil problem
Old Feb 17, 2011 | 06:09 AM
rxr2's Avatar
Default audi A6 1,8t AEB 99 oil problem
I’ve some problem with oil warning. When engine is hot some like 90C and I’ve accelerate more than 3000RPM FIS shows me Oil warning then when pushed left button to check what is going on the message is: “switch off engine, check oil level”
It happens often and always when engine is hot.
Untill now I have check ed:
Oil pressure in 2 way on hot and on cool engine and the result was:
IDE 1.6 BAR
2500 RPM between 3.2 – 3.4 BAR
5000 RPM 4.6-5.3bar
replaced head gasket and completed rebuilding the head .
compression result :
11.6 11.8 12.0 11.8
Replaced pressure sensor cause I have observed that during pressure measure when I plug off the sensor, on dashboard I have the same warning “switch off engine, check oil level”
So you may be guess how was my surprise, I thought that will be some like “ stop check oil pressure” I think the all sensor temp. , press. and oil level are connected with one warning.
And still have the same problem “switch off engine, check oil level”
Today I’ll change temperature sensor, and I should mention that I didn’t find oil level sensor,
I search that sensor on sump but with miserable effects.
What’s now ?
marcoetreni
Oct 12, 2009 03:32 PM
cgroff5686
Apr 7, 2009 09:12 PM
Mikesd1980
Jan 11, 2008 11:11 PM
johnstef
Aug 30, 2006 12:42 PM
audidaft
Feb 23, 2006 01:28 AM
