Audio addon
Old Feb 9, 2009 | 02:20 AM
gamebrigada's Avatar
Default Audio addon
I love the sound quality of the Bose system that I currently have, and as far as I know, its very difficult to find a stereo system that will replace your old one and use all the features of the Bose system. So I am wondering, If I buy this (link below) how would I go about connecting it for best sound quality. I saw that there are kits to connect an ipod through the cd changer cable and keeping the changer, can I wire this up instead? Would it work well or be a hassle?
Also thinking of getting a slightly stronger subwoofer, can I do that or is it not possible with the bose system config?
http://www.newegg.com/Product/Produc...82E16882117256
Thanks for all the help.
Old Feb 9, 2009 | 06:06 PM
Mattazaudi's Avatar
YOU can use this to install it, this is the dash kit, wireing harness (industry standard color coded for easy install), antenna adapter, and stock radio removal tools, I would suggest picking up another pair of these (4 all together) and have a friend help you out with the removal.. this will work with all of your speakers, you will loose CD changer if you have one, and the radio/ cd track display in the instrament cluster..
Old Feb 9, 2009 | 07:04 PM
Jeffreys's Avatar
I have wired up all my sub and amp, but I got a harness but it doesnt fit because of the Bose system. Do u know which Harness it is? All I need to do is plug in the head unit n im ready to go!!
Old Feb 10, 2009 | 03:27 AM
Mattazaudi's Avatar
Should be Metra part #
Metra Electronics Corp. 70-1784
or
Metra Electronics Corp. 70-1787
im thinking the 70-1787 is the right one, because it has RCA low level inputs, which is what you normaly see on factory amplified car harnesses..
Old Feb 11, 2009 | 06:28 PM
kavan's Avatar
Is it in the 09 A4?
I wanted to upgrade the stock sub to maybe a Bose one and change the amplifier with it would that get me a bit more bass ?
Old Feb 12, 2009 | 10:44 AM
Mattazaudi's Avatar
The Bose doesnt give you enough bass IMO to be worth the money of swaping it in. My buddie has a bose system in his A6 and the whole system sounds slightley louder than mine... what I would do is get a small 8 or even 10, nothing real high powered, in a small box with a small amp 50-100Watts RMS. that will give you some nice clean bass with out being too expensive.
fabric8
Jan 6, 2014 11:43 PM
guest196826
Nov 25, 2011 07:36 PM
huggybearv1
Jul 3, 2011 07:22 PM
jargan04
Nov 6, 2007 04:09 PM
smokeU
Aug 28, 2006 02:11 PM
