Clock adjust and auto windows
Old Mar 31, 2013 | 03:00 PM
bha280's Avatar
Default Clock adjust and auto windows
This is my first Audi and after searching I'm having trouble finding the answers I need. First, the gauges were recently changed and the time/date is wrong. How do I set it? I'm usually pretty good at figuring things like that out but am stuck.
Second, when I got the car the windows were auto up and down except for the rears which were only auto down. I had to disconnect the battery and now none of them are auto up or down. How do I change it back?
Old Mar 31, 2013 | 11:01 PM
mattymo's Avatar
Default clock
Not sure about your model but if it's like my A3 there is a **** or button below & to the right of the tachometer for the clock. There's one below & to the left of the speedometer for the trip-meter. You pull the **** to "select" hours/minutes and rotate to **** to edit.
I would think the window operation was the default. I believe there are some comfort items that can be controlled through the VAGCOM software. I don't have the software needed (do have the cable), the lite version I got only had a serial port & wouldn't work USB.
If you don't find any answers McC Audi in Mobile has answered several questions for me over the phone.
Old Apr 1, 2013 | 12:50 PM
bha280's Avatar
Thanks Matt. I tried pushing that **** and holding it but never thought of pulling it out. I'll give it a try. The windows started working on thier own this morning, so no need to mess with that.
Old Apr 17, 2013 | 04:28 PM
tofast2belast's Avatar
after you unplugged the battery, for auto windows to work, the module must "learn" the limits of the window. what you do is:
1: put key in ignition and turn on
2: press and hold down on drivers window button until window is all the way down
3: release the button
4: pull and hold up on the button to bring window up until the window has reached the top
5: release button
6: test the auto down function.
7: repeat above steps for other windows too.
sometimes you have to do it a couple times to get it to work.
padylam
May 9, 2011 06:22 PM
Jose Alvarez
Oct 27, 2010 12:07 PM
Jose Alvarez
Oct 22, 2010 01:42 PM
pmkcolorado
May 8, 2010 08:31 PM
TBarCYa
Feb 15, 2007 04:33 AM
