Determining cubic space within an enclosure
Old Aug 21, 2007 | 09:35 AM
A4 Effort's Avatar
Default Determining cubic space within an enclosure
Could anyone instruct me on the best way to measure cubic space within an existing enclosure? I have a jl audio stealthbox and i'd like todetermine what the cubic measurements are on each side that houses the 8" subwoofer.
Unfortunately this isn't a simple "box" design, as it contains angles and pockets internally.
Old Aug 21, 2007 | 04:12 PM
kraylon's Avatar
Default RE: Determining cubic space within an enclosure
enter measurement here---->http://www.rockfordfosgate.com/rftech/box_wizard.asp
Old Aug 21, 2007 | 06:05 PM
JamesTheGame's Avatar
For a box like that, you generally have to fill it up with something (sand, packing peanuts, water, etc). Then, pour the "filler" in to something and calculate the volume. You can probably just call JL and ask them, though
Old Aug 21, 2007 | 07:20 PM
A4 Effort's Avatar
Yeah, i actually had that idea in mind but was hoping it wouldn't have to come to that. Good point on contacting JL, i'll give them a shout.
Thanks!
Old Aug 22, 2007 | 10:20 AM
If JL won't give you the info, find out what sub they "recommend" for that enclosure. Chances are, the volume is the "optimal" box volume for that sub + displacement volume of the sub. So, if they recommend a 8w3v2, the volume of your box is probably around .41 cubic ft (.375 + .035 )
Old Aug 22, 2007 | 11:18 AM
A4 Effort's Avatar
The stealthbox was originally designed, and came with, the jl audio 8IB4 infinite baffle subs. When i bought the box, the guy did not have the 8IB4s, so he gave me a set of Kicker RMB8 infinite baffle which do not fit. So i bought a set of jl audio8W0-4s and put them in instead. They sound 'okay', but they really do not like that box. The 8IB4s are discontinued and are very rare andhard to find.
The box is designed with multiple openings where it mounts against the deck lid, and two large openings right above the subs. So i was thinking about sealing those openings and then finding a set of subs that would be ideal for that space; depending upon what the cubic measurements were.
Don't have a spec sheet for the box, but here is the 8IB4 spec sheet:
http://mobile.jlaudio.com/pdfs/8-12IB4_BDS.pdf
Old Aug 23, 2007 | 01:52 AM
csuflyboy's Avatar
What 'box' are you talking about that came with the IB4s? Those subwoofers are designed for "Infinite Baffle" (IB) use. Since that model has been discontinued, I can suggest some other suitable replacements...
Jeremy1976
B8 Models
Dec 29, 2009 09:34 AM
billjames
Oct 25, 2008 08:26 PM
viper9821
Apr 22, 2007 11:11 PM
RCFerrari
Jul 28, 2006 05:19 AM
ckandes1
Jan 16, 2006 04:50 PM
