Electronics/Wiring Guru's...NEED ADVICE
So I just got done installing my HID kit and when using relay harness that came with the kit, the directions asked me to make a connection to only ONE headlight bulb harness, therefore the other one is left alone.
So the HID's work great, but now what's happening is the computer is saying that one of my bulbs is out, it beeps inside the car, where I need to figure out how to trick a computer or make some kind of connection loop on the other harness to trick the computer and make it believe that there's an actually a functioning bulb, so the computer can stop tripping?
Does anyone know how I would do this? I'm thinking some resistor or fuse could be plugged into the other harnes to make it seems like it's an actual bulb?
Please help?
Please help?
RE: Electronics/Wiring Guru's...NEED ADVICE
I would do exactly that. Use a handheld meter and measure the resistance of one of the standard headlight bulbs, then go to Radio Shack or an electronics shop and get a resistor of that (or close) impedance, and you can probably just plug it in across the terminals of the harness. That will most likely solve your problem.
Glad this was brought up, as my HIDs arrive today and I'll likely run into the same issue on my car - I've only been an Audi owner for two weeks, and didn't even think of this - thanks
After doing some research, few other cars had similar problems like BMW's and Volvo's but they found a solution with a resistor but there was more to it. I just picked up a resistor from radio shack tonight and I'm going to try it tommorow.
I'll let u guys know if it works.
Thx
p.s. I think you can leave the bulb plugged in but it will shine underneath the hood. I'm also thinking of painting the bulb black with some heat resistant paint? Let's be creative haha
Thx
Finally, all systems checked OK, no more bulb out error....I used 2.2 ohm resistor in between and woks fine. I did connect it directly though, i didn't use the relay harness because then you hook it up to only one healight harness, if you go directly then both sides have their own hook ups, and that's where you would use the resistors.
PM me if you need more info...
thx
thx
rawdney88
04-19-2011 10:51 AM
