Fog lights not working / No Fuse in panal
Hello,
So the right front fog light was out, the left one was still working. Took the bulb out and it was indeed broken. I replaced both bulbs and now neither one are working. Checked the fuse panel and found that the fuse position 19 indicated for the fog lights was vacant. Also vacant are both the positions for the right and left headlights 20 and 21. The fuse panel map notes that all three should have a 15a fuse. I think that car has factory HID lights, could that be why there is no fuses? If this is normal what else should I check to get my fog light working again. My headlight appear to be working fine other than they seem to dim a bit at low idle.
If anyone has some insight on this let me know, thanks.
