G38 Gearbox speed sensor
Old Dec 12, 2013 | 05:44 AM
DanskAudi's Avatar
Default G38 Gearbox speed sensor
I'm totally up against the wall with this one, please HELP!!!!!
Our car
Car: Audi 80
Year: 1995
Model: Avant (Station Car)
Engine: 1Z motor 1.9 TDI
Gearbox: CLF 4 speed automatic
Donor Car
Car: Audi 80
Year: 1994
Model: Saloon
Gearbox: AEG 4 speed Automatic
One of the oil cooler pipes taking oil from the gearbox to the cooler sprang a leak due to rust draining the gearbox of oil. After fixing the problem with the pipe we refilled the gearbox and it has worked for six months until last week. I tried to find a matching CLF Auto gearbox but did not succeed and a new or reconditioned one was way too expensive. So I bought a donor Audi 80 TDI from 1994 with a AEG Auto gearbox because the are the same ratios.
However, after fitting the gearbox I now have no 'gearbox speed sensor' because there was no sensor on the AEG box while there was one on my CLF box. Due to not having a reading from the gearbox speed sensor my Avant is in continuous 'Limp' mode. The 'gearbox speed sensor' code is G38 which is located on the center left top of the gearbox. There's another sensor 'G68' which is the car speed sensor.
I think I have three options to try and get it to work.
1. Try to find a bypass for the G38 gearbox speed sensor to that the car will drive normally, is this possible, can it be bypasses? What I don't understand is how it worked in the 1994 Audi without this sensor?
2. Swap the complete wire harness and ECU from the 1994 to the 1995. I have tried this!!!!! However, the car would not start and I'm assuming it's because to two wires from the 1994 harness that didn't have anywhere to connect to on my 1995 car. I'll attach a picture of the two wires, one is a heavy wire that's black and grey and the other is light and is brown and black. Any ideas?????
3. I could remove the AEG box from the car (not so easy!) dismantle both gearboxes, and transfer the guts from the AEG box to the CLF housing which would give me a unit with a gearbox speed sensor! That's assuming that the parts are interchangeable?
What to do, any ideas, has anyone had or hear of this problem before?
Please HELP!
Old Dec 16, 2013 | 12:38 PM
Jeff-AudiUSAParts's Avatar
Former Sponsor
I don't have a lot to offer here, other than what the parts diagrams show. It shows the sensor as 095-927-321-C and bolting to the side of the transmission on the case. It is listed as both G38/G68 in the diagrams also. So there is no place to mount it on the donor trans then? Also, fyi, the valve body is a different part number between the two trans models, but gear ratios between the two trans is the same.
spiketrial
Oct 10, 2013 09:51 AM
recoil1987
Feb 10, 2013 12:25 PM
Toms Ķiris
Sep 11, 2012 06:52 AM
kbuff97A4
Mar 1, 2007 10:24 PM
