Good brand of HID kit? burned out HID...how to fix?
Old Jul 11, 2009 | 10:05 AM
CRAZYHAWK's Avatar
H7 indicates an after market HID kit.
D2S bulbs would be OEM.
Old Jul 11, 2009 | 06:52 PM
pa4ul's Avatar
actually h7 is stock halegeon lights and ds2 are stock hid.
Old Jul 11, 2009 | 11:00 PM
CRAZYHAWK's Avatar
pa4ul, he has an after market H7 HID kit.
Old Jul 22, 2009 | 05:05 PM
pa4ul's Avatar
i have stock Halogen capsule headlights and they are h7.
Old Dec 18, 2009 | 01:43 AM
poonamt93's Avatar
Check the wiring to be sure you have all good connections....check to make sure you have the proper voltage/amps for the HID bulb you are running...Could be overloaded. Most likely need to replace the ballast all together. Check the amps/volts with a meter to make sure the ballast is actually not getting power first...If it is getting power but continues to fail to ignite, you may be overloading it.
Old Jan 1, 2010 | 06:32 AM
noeal's Avatar
Hi,
Try to search it in any of the following search engines (google, yahoo, msn, bing etc..) you will get the required information. Type the the word for example you are looking information about (OEM ballast), then type this(OEM ballast) word any of the above search engines.
Old Jan 1, 2010 | 10:50 AM
CRAZYHAWK's Avatar
MAC5Gem has probably fixed his problem. Why bring this thread back.
He has an H7 HID kit, and can't use OEM ballasts.
Old Dec 8, 2010 | 06:32 PM
  #18
bradtyler02's Avatar
couple spammers up there
CheckerBird
Jan 4, 2015 02:24 PM
CheckerBird
Sep 14, 2012 04:03 AM
papachewlo
Dec 8, 2007 11:15 AM
a4awd
Nov 30, 2006 04:34 PM
SAudi
Oct 28, 2006 04:55 AM
