Hard Faults in 46 Central Convenience
Old Dec 31, 2015 | 08:03 PM
rtwintle's Avatar
Default Hard Faults in 46 Central Convenience
I keep getting a couple of codes related to my brake/tail light bulbs on both the right and left sides. I can clear them and they instantly return. I checked the lights and they are all working (based on the output tests and actually having someone do the brake and turn signals). I tweaked the coding and still the same two codes return. I checked the wiring guide and it shows the lights going directly to the j393 controller. I can't find anything related to this on any other thread so I'm hoping someone has some ideas on what would cause these two codes. I was theorizing that since things worked that there wasn't a wiring issue and was likely a coding issue, but according to the VCDS helper, it's coded correctly. It's a 2010 Audi A6 with facelift. Thanks!
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 N HW: 4F0 907 289 N
Component: Komfortgeraet H29 0250
Revision: 02500029 Serial number: 01244867950000
Coding: 5208253 --> I also tried 4618397
Shop #: WSC 02335 785 00200
VCID: 356141765C62D69692-8060
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
2 Faults Found:
02742 - Bulb for Brake/Turn Signal Light; Left
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 11
Reset counter: 85
Mileage: 25159 km
Time Indication: 0
Date: 2013.04.22
Time: 08:45:11
02743 - Bulb for Brake/Turn Signal Light; Right
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 84
Mileage: 33026 km
Time Indication: 0
Date: 2009.06.21
Time: 02:31:24
Old May 13, 2017 | 01:26 PM
leeuwarden's Avatar
I have the same problem. When I clear the code, the error code comes back immediately with the original date (a few months ago compared to today's date), which almost indicates that clearing does not work. Did you figure out what caused this and/or how to resolve?
Old May 13, 2017 | 03:04 PM
rtwintle's Avatar
Default Connectors
I wish I could remember with certainty what I finally did. I remember initially thinking it was a coding issue since everything worked and I recall playing with that, but I believe it would still throw a code. I do remember disconnecting all the connectors from the module to the brake light by removing the right rear cover and reconnecting them and making sure everything was clean and snug.
Old Feb 24, 2020 | 09:34 AM
Mwales41's Avatar
Default Solutions?
I'm having the same issue with my 2011 a6, I was hoping someone has found the fix to this issue
antmcfadden
Sep 20, 2015 04:54 PM
turboa3
Apr 20, 2015 09:10 PM
mikehinnenkamp
Apr 2, 2012 03:20 PM
lozts
Mar 5, 2012 08:16 PM
lukacio
Jul 15, 2011 02:18 PM
