help fault codes
Old Jul 15, 2011 | 02:18 PM
lukacio's Avatar
Default help fault codes
Hello
Can anyone help with the problem on the park brake on my audi a6 2005? he park brake started to show faults. It still works fine, but puts up the amber warning most of the time. I have changed the switch with no effect.
pls help me, what can i do with this fault codes?
Report below.
Address 53: Parking Brake Labels: 4F0-910-801.lbl
Control Module Part Number: 4F0 910 801 HW: 4F0 907 801
Component and/or Version: EPB C63C0030 H03 0030
Software Coding: 0005022
Work Shop Code: WSC 02334 785 00200
VCID: DDBA05F03B6B18F4
2 Faults Found:
01316 - ABS Control Module
013 -- Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 20
Reset counter: 240
Time Indication: 0
Date: 2011.07.15
Time: 10:58:41
Freeze Frame:
Voltage: 13.25 V
Count: 236
02444 - Disk Drive Load / Eject Malfunction
012 -- Electrical Fault in Circuit - MIL ON
Freeze Frame:
Fault Status: 11111100
Fault Priority: 2
Fault Frequency: 27
Reset counter: 195
Time Indication: 0
Date: 2011.07.05
Time: 20:26:02
Freeze Frame:
Voltage: 11.59 V
Count: 40
Thursday,14,July,2011,21:26:20:36838
VCDS Version: Release 10.6.2
Data version: 20101123
after i erased fault codes
Fault Codes have been Erased
1 Fault Found:
02443 - Control Head
Freeze Frame:
Fault Priority: 2
Fault Frequency: 27
Reset counter: 195
Mileage: 176384 km
Time Indication: 0
Date: 2011.07.05
Time: 20:26:02
Freeze Frame:
Voltage: 11.59 V
Count: 40
Thursday,14,July,2011,21:28:09:36838
and this
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Control Module Part Number: 4F0 910 517 L HW: 4F0 614 517 L
Component and/or Version: ESP 8.0 quattro H03 0090
Software Coding: 0020895
Work Shop Code: WSC 02325 785 00200
VCID: 2D5A15308B4B2874
1 Fault Found:
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 19
Reset counter: 240
Mileage: 176395 km
Time Indication: 0
Date: 2011.07.06
Time: 22:04:19
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4282
Hex Value: 0x0035
Hex Value: 0x01AC
Hex Value: 0x00FF
Thursday,14,July,2011,21:29:05:36838
m.c.
May 2, 2012 01:40 PM
PandaXpress
Jul 25, 2009 10:47 AM
1Move
Dec 1, 2007 05:37 PM
mitao2000
Aug 30, 2006 11:53 AM
BaconBait
Aug 8, 2005 08:21 PM
