HID Installed - Bulb Out Display - FIXED
Old Dec 13, 2006 | 03:37 PM
AAudiA6's Avatar
Default HID Installed - Bulb Out Display - FIXED
Some or many of you had a problem after installing your HID Kit upgrade with a bulb out reading on the dash. Well I found out how to fix this with a simple resistor plug/connection.
I've attached a small write up diagram picture on how you can connect the Resistor.
Good Luck
Old Jan 24, 2007 | 12:05 AM
nexusgroove's Avatar
Default RE: HID Installed - Bulb Out Display - FIXED
I installed HID Head Lights and HID fog lamps
The head lights don't report a problem but the fog lamps always popup as a problem, I tried the 2.2k Ohm trick you posted but nothing.
1/2watt 2.2k is what I used.
cheers.
Old Jan 24, 2007 | 07:29 AM
BadLuckAudi's Avatar
nice write up man
Old Feb 4, 2007 | 03:04 PM
DirtySouth's Avatar
I cant stop the damn things from flickering.... they're both like nightclub strobelights
Old Feb 8, 2007 | 12:28 AM
bmr18t's Avatar
i have the vision kit and it only pulgs into one connector. did you put the resistor in only the one it plugs into or both?
Old Feb 8, 2007 | 12:31 AM
bmr18t's Avatar
i got it one for each side sorry missed that part
Old Feb 22, 2007 | 05:47 PM
sivart2000's Avatar
How are the HID fogs? I have the regular beam HID's and was thinking about getting the fog lights. I also had that problem but it seems to have gone away by itself, though every now and then comes on and off.
Old Mar 14, 2007 | 01:16 PM
mlally333's Avatar
will this same type of trick work with my LED tail lights that got a lower resistence than my data transfer bus. My mechanic said an inline resistor would work but... has anyone had this problem. My light out signal comes on every time my brakes are on.
Old Mar 16, 2007 | 04:49 AM
SharpHID's Avatar
Did you ever get this fixed? This is a common problem with certain HID kits especially on new cars - there are fixes available other than a resistor. How did you end up fixing this? Some cars respond differently to different fixes.
Old Dec 16, 2007 | 01:39 AM
kawgomoo's Avatar
hey guys, you need to run what is known as a canceler box for your hid kits. some of the newer ballasts are "digital" and they have the parts built in. older and more generic kits {believe me its hard to tell} need this canceller or digital wiring harness as its sometimes known. they sell for about 40 bucks per pair. you can email me at xbunlocked@hotmail.com and if you are having trouble finding them. i just stumbled across this forum trying to fix an issue with a diesel truck that stalls everytime the hids are lit.
