Hid kit problems
1. on the out port pins of the harness, you have to take a flat head screw driver and open up the gap just a bit. it will then snap into a tight fit
2. remove the stock O-rings from the stock bulbs, and use them to replace the new ones (replace the orange ones with the yellow ones) this will allow it the bulb plug to fit perfectly in your headlight arrangement
3. it flickers when you do not have the engine running..
4. to reset the safety thing, unhook your battery for like 10 minutes, and re connect it, it should work, just make sure your engine is running when you try it again.
good luck
good luck
Smokin Tubes
Feb 5, 2012 10:11 AM
commedecargons
Nov 9, 2005 06:43 PM
2002, 2009, 35, 55, a4, abs, audi, b6, electrical, hid, interference, kit, problems, troubleshooting
