how to run with only fogs on????
Old Jan 28, 2007 | 12:46 AM
04a4's Avatar
Default how to run with only fogs on????
How do i set my 2004 A4 to run with only fogs on??? Right now they can only be on with the headlights, but you can pull the headlight **** to the fog position but they don't turn on???? How do I get this to work?
Old Jan 31, 2007 | 09:52 PM
TKneedsS4's Avatar
Default RE: how to run with only fogs on????
not familiar with 04 a4's but i know on the B5s4 you need to open the light board behind the glove box and solder a wire from one of the pins to another so you can have independant fogs. If its possible on the 04, i owuld goto audiworld and search their forum they have all the tech tips and how to's stickied.
Hope it helps and hope it was as easy as mine.
Old Feb 21, 2007 | 04:18 PM
dblock110's Avatar
you can use a VAG-COM and flash it to the computer
Old Feb 22, 2007 | 02:45 PM
Boston Driver's Avatar
ORIGINAL: dblock110
Correct, with the B6 A4, all you have to do is change a setting in the Central Electronicsmodule via VAG COM to "Rest of World" (0xxx1) instead of US (0xxx3), and the fogs can run independent of the low beams.
Old Aug 25, 2007 | 10:42 AM
tsloan71's Avatar
Can this be done on a 04-A6-3.0 quattro? I hate not being able to run with just fogs.
A4 2000
Jan 30, 2012 09:08 PM
Gigantor
Apr 6, 2009 09:17 PM
jaw knee
Mar 27, 2009 12:13 PM
cburn25
Feb 22, 2009 07:39 PM
PCBOI808@HOTMAIL.COM
Jun 30, 2008 05:07 PM
