Replaced Alarm Horn?
Old May 17, 2006 | 04:42 AM
kshkid's Avatar
Default Replaced Alarm Horn?
Has anyone replaced that anoying, low-volume alarm? I'd like to know if any success stories, like did it get replaced with a regular "horn" rather than a beeping device, or a professional alarm system? Thinking of replacing it myself with a regular horn, powered by the 12v accessory power in Avant trunk.
I have 2003 A4 Avant, body B6. Any suggetions? Thanks!
Old May 22, 2006 | 09:51 PM
houndz's Avatar
Member
Default RE: Replaced Alarm Horn?
You should be able to disconnect the stock alarm horn and use the same wires to connect a 12 volt alarm siren. Any 12 volt siren should work. The brown wire is usually the ground and the other is 12V+. Check it to make sure. I did this on my 1998 A6 and mounted the siren underneath my car. It works great. and it is loud as hell.
abarmard
Mar 29, 2015 09:52 PM
nene06
Aug 10, 2010 03:32 AM
pimphell
Apr 26, 2008 05:07 PM
socaljoe
Nov 7, 2007 02:42 PM
kshkid
May 17, 2006 06:02 AM
