Sub problem on bose system 02 a4
Old Nov 8, 2006 | 07:03 AM
tj19855's Avatar
Default Sub problem on bose system 02 a4
i connected evrything right. exept for the remote wire, where does it go? and the rca connector on the line connecting to the stock sub is this right? or it has to go somewhere in the stock amp?. amp goes on and everything but nothing from the sub. i know my rca connector is not hoocked up right.
Old Nov 8, 2006 | 09:26 PM
Zrowcool's Avatar
Default RE: Sub problem on bose system 02 a4
i dont know the exact pin on the b6 but i know for sure you can get a fuse tap and then run it to the fuse box off the radio or accesory fuse. dont skimp on agood fuse tap. really inexpensive and well worth it. as for your rca im confused as to where you have it. pics or even a wiring diagram would help a bit.
Jstephen
Mar 7, 2012 06:24 PM
picco97
Mar 22, 2009 01:06 AM
pbody
Apr 11, 2005 12:31 AM
spearhead
Jan 12, 2005 04:34 PM
