Upgrade A8 Tail lights...
Old Feb 23, 2013 | 11:07 AM
arayofelvis's Avatar
Default Upgrade A8 Tail lights...
I was given, but lost a link for instructions, etc. on how to upgrade my tail lights on my 05 A8 to a later model. Lights fit "footprint", however, going to LEDs will change draw. Apparently there is a conversion "harness" or "kit", I'm just not sure where to find? Thanks.
Old Sep 13, 2015 | 06:05 PM
antmcfadden's Avatar
Default Did you find your answer
Hello I know this is old but did you find an answer . Im trying to do same thing.Thanks
Old Sep 27, 2015 | 11:51 AM
cold_surfer's Avatar
Default Dont install "resistors"
trying to upgrade to LED DRLs I discovered: the inline 50W 6ohm resistors are heating up to 335F on the exterior, according to my digital infrared micro temp. They are also EACH drawing 50W of alternator output, putting more load on the alternator than the bulbs. You will find the higher draw either makes wire insulation more brittle or it will bake the insulation right off the local wiring harness.
Old Sep 27, 2015 | 11:59 AM
FishEye
Mar 25, 2012 03:13 PM
TagsAudi
May 31, 2007 05:55 PM
sh500
May 24, 2007 02:27 AM
mypreludeisred
Aug 9, 2006 11:08 PM
