V1 Install Q --- Worked, now it doesn't
Old Mar 14, 2008 | 09:51 PM
BlueC5Kitten's Avatar
Default V1 Install Q --- Worked, now it doesn't
I hardwired my V1 about a year ago when I first got my '07 S4 using the fuse connection, and the detector worked perfectly for about 3-4 months, then started getting intermittent power, and then eventually nothing. I have checked the fuses and the wiring and all is as it should be (no blown fuses, no codes), but I can't get the hardwire to run the detector. I hate having the cord dangle from the detector on the windshield, but am living with it now, as I do still enjoy a spirited drive. Any thoughts?
Old Mar 27, 2008 | 02:28 PM
Audi 90Sport Quattro's Avatar
Default RE: V1 Install Q --- Worked, now it doesn't
What did you hardwire it too? Did you use the V1 hardwire kit?
Old Mar 27, 2008 | 10:40 PM
Yes, hardwired to an ignition-on only fuse.
Spoke with some guys in a local drive group and they recommended Tap-a-Circuit so there is not fuse interrupt.
Old Mar 28, 2008 | 12:15 AM
yeah that is correct. My installer used some piggy backed type of fuse connecter for my V1 and laser jammer to my ingition source.
Old Jul 7, 2008 | 11:32 PM
02audia41.8's Avatar
Default RE: V1 Install Q - Worked, now it doesn't
its probably your wire i had mine wired in on my a4 for about a year then when i went to put it in my s4 2 days ago it didnt work so the wire just went bad but luckily had a new one
Old Jul 8, 2008 | 01:10 AM
Thanks for the thoughts! It's a fairly new unit, so shouldn't be a problem with the wiring...well, a year old now...but have been using the regular cord since it winked out the first time 'round, with no issues.
Anyway, bought an in-line fuse connector, which didn't seem to help at all...but now have the line directly linked to the fuse for the garage door opener (which I thought was ingition-on only, but the detector stays on when the car is off [:@]), and it works fine...who knows what the deal is...just have to remember to turn on and off now.
Old Jul 10, 2008 | 02:12 AM
The reason your V1 is staying on is because of the connection to the garage door opener location. That has constant power, so just hardwire it to the ingnition so you have turn key power on and off.
Old Jul 10, 2008 | 03:56 PM
Not sure what you mean, it"has constant power," as I am not able to operate the garage door opener when the car is in the ignition-off without a key.
I've hardwired radar detectors (including V1s) before and anytime I used a fuse that is associated with an accessory-off with iginition-off has always worked.
Appreciate your suggestion...will give it a try!
Jeremy Decker
Mar 17, 2013 11:38 PM
MiniSpdRcr
Nov 12, 2007 08:21 AM
