Exterior Talk about your rims, body kits, and other exterior mods here.
BIG rotors
Old May 13, 2005 | 05:44 AM
mlo517's Avatar
Default BIG rotors
I really want to get the biggest rotors possible for my car. I dont want to spend more than 150-200 a pair, does anyone have any recomendations? Im getting some really open rims and I dont want crappy looking stock rotors being seen through them. I want to get the biggest rotors possible. Please post what you think i should look into........
Old May 17, 2005 | 12:08 AM
shane's Avatar
Default RE: BIG rotors
I hate to be the one to break it to you (no pun intended), but you're not going to find "big rotors" for $150-200 a pair. Big brake kits typically run about $1,800-$3,000. Check out StopTech, Brembo, or a Porsche Big-Red upgrade if that's the route you want to go.
If you want a less expensive alternative, you can grab some cross-drilled or slotted rotors. The TireRack has them for around $200 a pair, and you have your choice between Brembo or PowerSlot. One thing to keep in mind, is you'll also want to replace your pads if you replace your rotors for the best results.
adamsrotors
B8 Models
15
Jun 25, 2015 02:08 PM
