Helix LED headlights for B6 A4
you can put some in yourself instead of buying a whole new assembly with them in it i just went to autozone baught two l.e.d strips used a hair dryers to soften the caulk holding the headlight together pulled it apart and then glued the l.e.d strips in and just wired the l.e.d's to my tail lights if you have the hid headlights you cant wire the lights to the headlights or you will fry the wiring to the headlights because of the difference of power after that i just caulked everything back together its cost me at total around 40 bucks you dont have to worry about heat eating the glue because hid lights dont get all that hot and the engine heat doesnt sit at the front because of the fans and water wont get in because of the hood
mcanedo92588
Apr 5, 2013 12:39 AM
Interceptor
Feb 10, 2009 01:46 PM
