Exterior Talk about your rims, body kits, and other exterior mods here.
HID's in fogs
Old Jul 10, 2010 | 07:59 PM
sinzbrosracing4a's Avatar
Member
Default HID's in fogs
I have the HID kit for the low beam but i was wondering if it was possible to put another hid kit on for the lower fog lights bulb h1's i believe. I dont see why not I just wan everything to match xenon has anyone done this?
Old Jul 10, 2010 | 09:34 PM
morgan82's Avatar
you can just get a kit try and see if you can find a plug n play one so you dont have to cut any wires
Old Jul 10, 2010 | 10:51 PM
ImTheDevil's Avatar
I did it last year. Works great but there's no plug and play - you have to drill out the back of the housings to run the HID wires. It's easy though - don't let the small amount of work dissuade you.
Old Jul 11, 2010 | 09:25 PM
Member
imthedevil is there a diy or anything on that?
Old Jul 11, 2010 | 09:41 PM
ImTheDevil's Avatar
Not that I'm aware of but basically install the bulb, drill the back of the housing to route the bulb/ballast wiring, and connect the car's fog wiring to the blade terminals on the bulb wires. That's it really. It's a very straightforward job.
Old Jul 12, 2010 | 11:23 AM
Member
im getting 8000k h7 and i want the fogs to match but i dnt no if 8000k fogs will cause melting or anything. lol
Old Jul 12, 2010 | 11:33 AM
ImTheDevil's Avatar
Nope - OEM fogs can take it no problem.
Old Jul 12, 2010 | 12:15 PM
pa4ul's Avatar
just make sure they are the 35 watt and not the 50watt.
Old Jul 12, 2010 | 02:02 PM
Member
pa4ul i dont think watts convert to k at all so therefore i have no clue if they would be 35 watt
Old Jul 12, 2010 | 02:18 PM
ImTheDevil's Avatar
Color temp and power draw are not related. Some places sell both 35w and 55w kits - specify that you want a 35w kit in the color temp of your choice.
