Exterior Talk about your rims, body kits, and other exterior mods here.
Size of Tires
Old May 10, 2006 | 06:30 PM
mtmaudis4's Avatar
Default Size of Tires
What size tires would I need to put on a rim 19x8.5 in front and 19x9.5 in back?? Also not making the tire look as if it were stretched.
Old May 11, 2006 | 04:57 PM
idnefe84's Avatar
Default RE: Size of Tires
you can try using 235/35(or 30 i forgot) for the front and 245 for the back.
you are using staggered wheels? is your car quatro?
cos i heard that if your car is a 4 wheel drive then it is not advisible to use staggered wheels. it will damage the 4-wheel drive system.
thats what i heard.
Edwin
Old May 13, 2006 | 12:31 PM
paulhiggs's Avatar
It will definately damage the quattro system if you use a wheel/tire combination that has different circumference front vs rear. Different circumferences means different axle rpm which would look like front/rear wheel spin (all the time)
235/35 has a sidewall height of 82.25mm
245/40 is 98mm
255/30 are 76.5mm
Trying to find combinations is very hard (probably impossible)
For a quattro, put on four wheell/tires that are the same
adam044
Aug 12, 2014 12:45 PM
cristi123
Jul 17, 2009 01:25 PM
fumoazul99
May 13, 2008 06:40 PM
metalmulisha
Dec 19, 2006 12:18 AM
d_maniac
Jun 21, 2006 03:41 PM
