Forum Issues Discuss any issues you are having with the new forums here.
P1106 came up.
Old Apr 26, 2010 | 11:48 AM
hernieA4's Avatar
Smile P1106 came up.
I have a 1997 2.8 quattro. P1106 came up. Reviewed couple threads and all suggest its pre-cat o2 sensor. How hard is it to change it myself?
Old May 1, 2010 | 03:46 PM
ImTheDevil's Avatar
That code is defined as either low voltage on the driver side pre-cat O2 sensor or an air leak. The air leak is a low-percentage chance so yeah, the O2 is the most likely. It's not too hard to change - unbolt the coolant tank and tip it out of the way and you should be able to get to it. You need an O2 sensor socket and probably at least a 12" extension to get it undone.
NYankee
Jul 18, 2010 02:16 PM
colm92116@yahoo.com
Apr 14, 2009 03:06 AM
Red Baron 97
May 16, 2007 10:48 AM
Topdown
Apr 25, 2007 05:29 PM
brandons34
Feb 27, 2007 12:32 AM
