1.8TURBO PROBLEMS, HELP!!!!!!
Old Jul 6, 2006 | 08:34 PM
mrmattholmes's Avatar
Default 1.8TURBO PROBLEMS, HELP!!!!!!
hey all, im new to this forum and i hope you can help me. i have a 97 R reg, a3 1.8t, engine code agu. I was driving it and the oil light came on so i plugged it into the fault code reader and nothing came up. then went to it and it would not start. so i took the cylinder head off, all the valves are ok, pistons are fine with no movement. so i took the sump off and realised the oil was really thick like syrup and the oil pump was clogged up. i have changed the oil pump and it still wont start. There is a spark at the spark plug and there is fuel getting through but seems to be no compression on any of the cylinders. the crank and cam are fine. What can be wrong?
the only thing i can think of is blocked oil feeds?? anyone had a similar problem? any help would be much apprieciated. Thanks Matt
Old Jul 16, 2006 | 02:06 PM
AudiGuru's Avatar
Default RE: 1.8TURBO PROBLEMS, HELP!!!!!!
Sounds like you have the timing off.
Old Jul 16, 2006 | 03:16 PM
timing is absolutely fine, there still should be compression unless the timing is miles out.
Old Jul 30, 2006 | 03:37 PM
dankhound's Avatar
Even with blocked oil passages the engine should still start. It wont run long without oil thou. Get a compression tester and a cylinder leakdown tester. Then youll know for sure wheter you have a compression issue or not.
Audia3boy
Jun 9, 2015 04:49 AM
CSUCwildcat4
Mar 21, 2014 05:25 AM
Misael.chacon
May 20, 2013 10:13 AM
Vicente007
Jan 5, 2010 04:30 PM
epitome
Mar 20, 2005 03:40 PM
