1990 A90 Quattro Noisey tappets.
Old Aug 15, 2007 | 04:08 PM
Mr Tickle's Avatar
Default 1990 A90 Quattro Noisey tappets.
When cold above 1.5 - 2k revs I have a noisey tappet/s (hydraulic lifters) It's quite a loud tapping too like the rocker cover is being hit by a small hammer. It's also very embarassing. Once the engine has warmed up to normal temp the noise isn't as loud and sometimes completely goes away.
Because of this I assume it's just the hydraulic tappets. Would I be right? Is it an easy job to replace them with new ones?
When I've looked through the oil filler the cam looks nice & shiney with no scores that I can see.
Thanks in advance
Old Aug 15, 2007 | 08:06 PM
auditech79's Avatar
Default RE: 1990 A90 Quattro Noisey tappets.
I would first have someone check your oil pressure before condeming the lifter buckets, chances are your oil pressure is not within spec and you should get that checked out ASAP.
Old Aug 16, 2007 | 12:27 AM
SAudi's Avatar
try using thicker oil, ive heard that the older these cars get you can start to hear the lifters tap, also are you sure its not your injectors going. it may also be that you need to change your gas octane rating, i remember i ran 87 for a while and the car retarded the timing so i was getting lifter/valve noise, as soon as i went to 93 octane everything is like peaches. but auditech is right insufficent oil will also cause this, make your you have oil pressure and oil gets to were its needed.
Lsand
Sep 23, 2007 10:31 AM
lidonnit
Jul 27, 2005 02:34 AM
aTiTude
Jul 8, 2005 09:15 PM
1987CSQ
Jun 8, 2005 12:18 PM
BostonS4
Oct 19, 2004 05:21 PM
