1991 200 20v turbo quattro boost lag
Old Feb 7, 2009 | 06:35 AM
Wakey200turbo's Avatar
Post 1991 200 20v turbo quattro boost lag
my 200 has a chip, clean intake, healthy turbo, steel braided fuel lines, etc. but still lags or "bounces" with boost at high rpms. ive had many technicians troubleshoot and to no avail. any ideas?
Old Feb 12, 2009 | 11:08 AM
matasci's Avatar
there is no lag at high rpms the turbo is already spooled up. your thinking of something else. hows the wastegate?
Old Feb 17, 2009 | 03:12 PM
the wastegate is a proper stock 30mm that operates fine. i meant that the boost bounces more than "lags". im not sure if its a fuel delivery problem or air consumption/discharge. looking into replacing all associated parts to rs2 spec....
Old Feb 21, 2009 | 05:27 PM
matasci's Avatar
how much boost are you running and have you looked at you turbos effficency map? theres only so much exhaust your motor can give the turbo maybe you are peaking the the volumetric effecency. and it has no more to give.
Old Feb 28, 2009 | 01:26 PM
airflow is 6121 cfm under 20lb/psi boost. not sure about the volumetric efficiency of the turbo. its stock.
Mudi
Jan 16, 2012 02:02 AM
In and Audi
Apr 3, 2011 11:52 AM
tailwinds
Dec 21, 2010 09:07 PM
dtmauto
May 12, 2009 09:30 PM
AUDIFANATIC88
Apr 18, 2008 02:57 PM
