19's on a B7 S4, Tire size?
Old Dec 30, 2006 | 06:00 PM
quidbert's Avatar
Default 19's on a B7 S4, Tire size?
This is my first post, but I was wondering can I fit a 19 inch rim with a ture that is not so low profile that the ride suffers? It is for a 06 S4 avant with stock suspension.
Thanks
https://www.audiforums.com/albumphot...Type=6&apage=1
there is my car now.
Old Dec 30, 2006 | 10:26 PM
Ninam's Avatar
Default RE: 19's on a B7 S4, Tire size?
That'll help you http://www.miata.net/garage/tirecalc.html. But PLEASE do not make the overall diameter of the wheel larger!!!
Old Dec 31, 2006 | 12:09 AM
AWDaholic's Avatar
Senior Administrator
the BASIC answer to your question is no, you can't. That being said, you cud make the suspension softer, but then you prolly end up slammin inoto the bump-stops, which suchs-dunkey-bools. The "rolling" diameter MUST remain teh same, as you can see from the Miata tire doohickey, or your speedo gets a skewered. Bigger WHEEL, means shorter sidewall height. Shorter sidewall height means a firmer, less compliant ride. Less compliant ride means more road feel, more grip (generally speaking), more spilled mega-ultra-gulps, and so therefore dirtier, stickier carpets...
Old Dec 31, 2006 | 12:39 AM
Ninam's Avatar
Bigger overall diameter and wider tiresalso give youpoor gas milage.
mystrodo
Sep 2, 2009 09:41 AM
fidelite
Jun 24, 2008 02:06 PM
EliteTuning1
Jul 25, 2007 04:15 PM
jtv4.2
Aug 29, 2006 02:00 PM
angelo_nyc1
Jan 7, 2005 06:33 PM
