2000 a6 info lights out help
Old Mar 18, 2009 | 01:00 PM
thunderrick's Avatar
Default 2000 a6 info lights out help
Hi i have a 2000 a6 2.7t and the info display in the center of the instrument cluster has only partial words and numbers even the low fuel warning sighn is only partially there , i assume there are pixels or bulbs out, how do i fix it and is it a hard job to do i am a mechanic.
Old Mar 18, 2009 | 03:02 PM
matasci's Avatar
its a common problem with the b5 audi's there is no bulb. it comes as a unit. its expensive and all you have to do it take the steering wheel off and then the consol itself.
Old Mar 18, 2009 | 05:18 PM
new_owner's Avatar
Depending on how much experience you have with instrument clusters... remove the cluster, remove the center display unit and re-seal it. It can get loose over the years causing loose pixels display. Some say it gets worse as it warms up...
Old Mar 18, 2009 | 06:16 PM
Do you need any special tools to pull the cluster, reseal it with what.
thanks
dguzzardo22
Sep 25, 2010 12:11 PM
blockp
Jan 30, 2008 01:04 AM
alexi21
Aug 2, 2006 07:27 PM
pherder
Dec 9, 2005 07:51 PM
kenzReid
Sep 21, 2005 02:45 AM
