2001 A6 master window switch group
Old Sep 26, 2010 | 02:21 PM
BL55422's Avatar
Default 2001 A6 master window switch group
Need to acces broken master contol switch, which is permanently engaged (won't lock down).
Ck'd here for any other posts and found the removal for the master switch group here: http://www.vaglinks.com/Docs/Audi/C5...Front_Door.pdf.
Here is the rub--everyone says its easy, but the diagram is not real clear on how/where to apply force to pop the switch group. I can't get enough illumination through the access hole to see if I'm pressing on plastic or metal (I assume plastic) and I don't have an interest in breaking anything. The diagram starts with the screwdriver going straight in, but then they seem to turn it vertical.
I have tried the following, all straight in: light force, diligent and greater force, and tapping with a hammer in case the release was frozen--noting budges the assembly. Any help or direction is appreciated as I can't think this is a big deal. Thanks in advance.
sabresfan
Aug 21, 2012 01:02 PM
little_town_audi_owner
Apr 23, 2011 11:32 PM
exequiel3k
Feb 25, 2010 08:14 PM
jj2345
Feb 27, 2009 05:29 PM
peterock29
Jan 16, 2008 03:59 PM
