2001 audi s4 problems
Old Sep 16, 2012 | 09:29 PM
staxbass's Avatar
Default 2001 audi s4 problems
replaced water pump, temp gauge, temp sensor.. still having overheating
issues. not sure what the rest of the problems are..
VCDS Version: Release 11.11.4 (x64)
Data version: 20120807
Sunday,16,September,2012,17:14:01:32551
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Address 01: Engine Labels: 078-907-551-AZA.lbl
Part No: 8D0 907 551 L
Component: 2.7l V6/5VT G 0001
Coding: 06751
Shop #: WSC 63351
VCID: 336BE5CD014A4F80EC7
1 Fault Found:
16502 - Engine Coolant Temp. Sensor (G62)
P0118 - 35-10 - Signal too High - Intermittent
Readiness: 0000 0000
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 8D0 927 156 DR
Component: AG5 01V 2.7l5VT USA 1819
Coding: 00002
Shop #: WSC 63351
VCID: 8001FA01807CA418A15
No fault code found.
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Part No: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04397
Shop #: WSC 12345
VCID: 356FDBD50F3E51B0C23
2 Faults Found:
18265 - Load Signal
P1857 - 35-10 - Error Message from ECU - Intermittent
18256 - Please check DTC Memory of Engine Controller
P1848 - 35-10 - - Intermittent
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 P
Component: A4 KLIMAAUTOMAT D58
Coding: 00160
Shop #: WSC 63351
VCID: 2D5FF3B5E76E1970BA3
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00304
Shop #: WSC 06335
VCID: 3A75C8E92620BEC82F1
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 981 B
Component: B5-KOMBIINSTR. VDO D12
Coding: 02264
Shop #: WSC 22186
VCID: 2B5BFDADD97A1740A47
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16232
Shop #: WSC 09144
VCID: 4081BA0140FCE418615
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 63351
VCID: E0C1DA81603C0418C15
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 63351
VCID: E5CFCB957F1E6130323
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00017
Shop #: WSC 22102
VCID: 24491691B4A4D83865D
End ---------------------------------------------------------------------
Old Sep 18, 2012 | 10:34 PM
ImTheDevil's Avatar
How about the thermostat?
Old Sep 20, 2012 | 04:12 AM
staxbass's Avatar
yes just changed that.. same issue.
my oil temp is about 250 when driving normal and my temp is a little past the middle from c to h. when I drive the car for a few min it smells really bad like rubber is melting or coolant is burning. I really cant figure it out.
Old Sep 20, 2012 | 04:19 PM
ECS Tuning's Avatar
Sponsor
Seams like your temps are about normal. Have you checked all your fan switches and relays?
Jason
Old Sep 22, 2012 | 11:15 AM
stevenangel121's Avatar
Thanks for sharing such a vital information, actually I am looking for information regarding. Now this thread definitely help me a lot.
Old Sep 23, 2012 | 11:39 PM
staxbass's Avatar
finally figured it out.. The secondary coolant pump had a leak.
Old Sep 26, 2012 | 06:29 AM
markar121's Avatar
Default 2001 Audi S4 Problem?
I have an 01 Audi S4, it's doing this f unky thing with the oil temp gauge, it will be at 150 then all the sudden go up to the red line then drop back down, also the gas gauge is not reading the gas level right, it said I had no gas when I really had half a tank. Anyway, sometimes it does this, then sometimes its fine. We checked the instrument cluster and there are no DTCs, anyone have any suggestions? Thanks!
muccamoofrog
Jul 30, 2015 08:11 AM
ossy1020
Mar 26, 2015 02:27 AM
GeondrayPeterson
Jun 24, 2013 03:04 AM
Eyejey
Apr 21, 2011 02:37 AM
aniloztuncer
Nov 23, 2009 09:53 AM
