2002 A4 Quatto windshield squirters
The windshield squirters were despending fine. then they stopped working....I checked the reservoir & added washer fluid and still no go. Would appreciate any feedback.
Get under the hood and listen for the motor to come on while someone else attemps to use the wipers. If theres no motor sound you most likely need a new motor. They are a pretty common failure. Also try turning on the headlights and see if the headlamp washers work. If neither works you probably have a bad switch.
wrxakaboosti
Sep 23, 2012 08:08 AM
