2004 Audi A8 - Jump Locations or Charge or Trunk Release?
Old Mar 20, 2014 | 04:19 PM
AudiA8driver's Avatar
Default 2004 Audi A8 - Jump Locations or Charge or Trunk Release?
Need some expert advice here.
I have a 2004 Audi A8 in which the key is stuck in a broken ignition. I cant release the key with the little button on the ignition switch as the ignition switch cylinder is spinning. There is also no power to the car at all and I cant access the trunk as the key is stuck in the ignition and wont come out.
I looked under the hood and cant find any jump locations where I can feed the car power so i can open the trunk.
Can someone help me here? I dont think there are jump locations on a 2004 A8 as this was a flaw in design. But how to get I get power to the car, or even some power just to get the trunk open so I can put a new batter and jump the car etc to get the key out?
Old Mar 21, 2014 | 06:22 PM
gsjohal's Avatar
Did you try the trunk release switch in the drivers door ?
Old Mar 21, 2014 | 07:45 PM
I didnt know theres a trunk release in the drivers door. Do you have pictures of it that you can show me? Also if that is powered it wont work because theres no power to the car.
Are you sure there is one for my model? 2004 audi a8?
Old Mar 22, 2014 | 04:57 AM
gsjohal's Avatar
Hi.
I'm sure it was a std fit on your A8, it will be a switch on the door pocket area with the fuel flap switch.
Are you not able to hold the key over to the left in the barrel and press the release switch, to remove it?
Old Mar 22, 2014 | 11:10 PM
Default Got it
Originally Posted by gsjohal
Hi.
Ok I was able to release the key and open the trunk to access the battery and jump locations. But here is my new problem.
Hello, How is it possible that my 2004 Audi A8 AWD is able to be pushed as though the car is in neutral all the time but the actual gear selector in the center console remains in park?
I bought a 2004 Audi A8 in an auto auction. The battery has been dead for a few months. I was just able to get the key out of the broken cylinder in the car and open the trunk to access the battery. When I placed a jumper pack on the car, all of the electronics on the car lights up but i get an error on the dash/mmi stating put the car in park or neutral in order to start. The car will not start. When I turn the key all the power turns off. The shifter is literally in Park position and does not move even if I push the brake. The MMI shows that the shifter should be in the S position if that makes any sense. Please help me, i have no idea what could be wrong. The car was a stolen recovery and the ignition cylinder is broken and is loose in the hole. But I can still put the key in and turn and the car just loses all electricity but the MMI still says put in Park or Neutral. Also, once the car was taken off the tow truck, we were able to push the car around and into a spot as if the car was placed in neutral. How could this be possible if I cant even shift the car into neutral with the shifter? is something broken or did someone break something since this car is AWD and broke something to be able to push the car since it can move as it is in neutral?
Country: United States
Make: Audi
Model: A8
Year: 2004
Engine: 4.2L V8
TTeriffic
Sep 28, 2016 10:38 PM
AudiA8driver
Mar 20, 2014 04:22 PM
rmwebb1
Jul 13, 2011 10:50 AM
cbouslim
Dec 25, 2008 11:48 PM
grandmasterflip
Apr 20, 2007 08:30 PM
