2006 A4 rough idle
Went to run my errands the other morning and within the first 5 minutes of my trek, my car started running really rough, as if a coil pack had gone bad. CEL came on and was flashing, turned around and went home (about a 3 minute ride). Ran my OBD and had the code for misfire in number 3. I swapped #3 and #2 coil pack and the issue followed to number 2, easy day right, not so fast. Changed the number 2 coil pack and cleared the code. Started the car and it was idling really rough, after a couple minutes, CEL came on. Ran the OBD again and received codes for all 4 cylinders misfiring, 0300 random misfire as well as 0171 for running lean. Figured what the hell and changed the remaining coil packs and plugs. Car still idled like it wanted to stall. In frustration, I closed the hood and decided to put the car on the other side of the driveway. Started the car after closing the hood and it idled just dandy, no rough idle at all. I should say that while the idle was rough, advancing the throttle smoothed everything out. I was thinking possible ICM but am not sure of its location. Any ides/suggestions would be most appreciated. I am a schedule for a military deployment in the not so distant future and would like to get the car fixed before I deploy. Thanks and Happy New Year to all!!
justinclarke
Nov 26, 2010 02:29 PM
justinclarke
Nov 25, 2010 04:03 PM
