2006 Audi A4-P2181 fault code
Old Nov 26, 2013 | 01:56 PM
g.ryan's Avatar
Default 2006 Audi A4-P2181 fault code
Hi Everyone,
Was looking for some help/insight...I have a 2006 Audi A4 (2.0T-Quattro) with 89,000 miles. I received a check engine light on Saturday, while driving down the highway. I had it checked at Autozone and they stated it was a P-2181 fault code or Cooling system performance issue. I did add Coolant two days prior as I was taking a trip. The car is not overheating at all, I drove over 150 miles with the check engine light on. I replaced the actual Fill Cap yesterday as I was thinking potentially not making a good seal, and once again checked the coolant level, theres max coolant but I still have the Check engine light on. I don't think its the radiator, waterpump or thermostat as i'm sure it would have overheated...so I am thinking it's the CTS Sensor...has anyone else had this issue. Thanks for your help.
Old Nov 26, 2013 | 04:41 PM
M5S5's Avatar
Tech Certified
You either have a bad thermostat (staying open too long) or a bad CTS.
Old Nov 27, 2013 | 09:44 AM
g.ryan's Avatar
Thank You..I changed the CTS last night...and that fixed the problem. Not the easiest item to replace (Mostly done blind or with a mirror) and found out that there are two different CTS's (2 pin connector (Grey) and a 4 pin connector (green). Mine was the 2 pin connector...thanks again.
Old Feb 26, 2014 | 02:53 PM
Hazim Mandavia's Avatar
did the code end up coming back? most people dealing with this code end up having to go further than the sensor. I'm asking because I have the same code coming up. The CEL goes away in warm weather (in TX, about 8-9 months out of the year) and comes back up when the weather cools down around freezing.
Old Feb 26, 2014 | 03:33 PM
ilackav8's Avatar
sounds like your problem is the thermostat
Old Jan 31, 2016 | 05:40 PM
pmakegood's Avatar
Hi Ryan,
Does replacing CTS sensor work in long term? I am having the same code on the same model.
Thanks.
Originally Posted by g.ryan
Hi Everyone,
Old May 30, 2016 | 11:59 PM
skibreeze's Avatar
I just had the check engine light and it had a P2181 code on my 06 A4 2.0L. My temp gauge was reading up to the 12:00 position, so I guessed that it was the coolant temp sensor and not the T-stat. The sensor was a PITA to see unless I used a mirror, but it was super easy to replace. I then disconnected the battery for 5 minutes to reset the check engine light. The traction control light will come on (as part of the battery being disconnected), but goes off after driving it for a few seconds. Thanks to those who started and responded to this thread, I wouldn't have been able to fix this without your help.
Old Aug 15, 2017 | 01:51 PM
Tincup's Avatar
I have an 08 TT with the same fault code is it the Thermostat or the CTS any help?
cordawg92
May 20, 2016 12:15 PM
yanelis
Apr 10, 2014 06:48 AM
Gdepo
B8 Models
Jul 25, 2013 05:44 PM
Shell
Apr 15, 2012 01:49 AM
afastrunner
Jul 10, 2007 01:13 PM
