2nd post....some problems I'm having...
Old Aug 19, 2008 | 10:06 AM
s'portaudi's Avatar
Question 2nd post....some problems I'm having...
In addition to the previous post, these are a few problems I'm having:
1. Car has trouble starting when I fill up with gas. Won't start and I have to pump the gas peddle to get it to start. Audi found nothing wrong! Anybody familiar with this?
2. Strange "grinding" sound coming from hood area. Only happens when I'm in a low gear at a higher RPM and let off the gas. Actually, more like a "whrrr whrr whrr" sound! (Hope that description makes sense!) Anyone else?
Those are the two major problems for now! Thanks for any responses!
Eric
Old Aug 19, 2008 | 08:30 PM
auditech79's Avatar
Helps to know what year, and model your car is....... Any fault codes?
Old Aug 20, 2008 | 09:52 AM
s'portaudi's Avatar
My bad! '03 A4 1.8T..............No fault codes. I took it in to Audi for the gas problem and no code came up and of course the problem never occurred when they had it. The second problem has just been something I've been noticing within the last few weeks.
Old Aug 20, 2008 | 06:37 PM
auditech79's Avatar
Well pumping the gas won't do anything to help start the car, it doesn't have a carburetor. However it has an electronic throttle body, so it could be the throttle valve is sticking. If you have a vag com you can check the percentage of the valve opening, if not take off the intake hose and have someone push down the gas pedal while you check the valve to see if it opens and closes correctly. That could also be the source of the noise.
Euro Dreams
Dec 6, 2019 03:38 AM
barney12
Oct 20, 2019 03:30 AM
m@rktt
Apr 30, 2008 12:04 PM
Cameron
Apr 19, 2007 04:01 AM
nhltfour
Jun 19, 2006 10:46 PM
