#6 misfire p0306
Old Nov 28, 2010 | 04:44 PM
Rusci53audi's Avatar
Default #6 misfire p0306
1998 a6 quattro 2.8 v6 has a check engine light on. Brought it over to autozone. Error code #p0306 came up.
The only thing I have tried so far is change the number 6 spark plug and disconnected the battery for a good 15 minutes. Started the car up and the check engine lights was on from the start. I'm not sure if disconnecting the battery reset the ecm at all.
I'm looking for a few suggestions on the steps I should take next. Is there a way to test the coil pack to see if it is sending a spark to the plug? Which o2 sensor I should check and how many o2 sensors are there? Any help is appreciated because I'm looking to do this myself.
Old Nov 28, 2010 | 06:31 PM
ok just researched and found out the disconnecting the battery wont work
Old Mar 23, 2011 | 10:52 AM
5th_year_senior's Avatar
go back to autozone and use the scanner to erase the code...
Old Mar 26, 2011 | 10:54 AM
ImTheDevil's Avatar
Most of them won't do it - they're subject to a $10,000 fine for doing so.
Old Mar 29, 2011 | 09:19 PM
v8crazy24's Avatar
Not sure about your specific car, but I had a misfire code and checked plugs, coils, and eventually led to the ignition control module being faulty. Not sure about the 2.8L but the 1.8T did and After I had it tested and replaced it, it got rid of the misfire instantly. Just something to look into
jwalters103
May 11, 2022 01:46 PM
02AudiA63L_65
Nov 11, 2013 07:30 PM
nismo350z_burak_tx
Aug 7, 2013 09:54 AM
HuskyRips
Aug 9, 2010 10:25 AM
gabeguimaraes
Feb 28, 2009 10:37 AM
