8k & clutch failed...dual mass flywheel?
Old Dec 6, 2006 | 09:26 PM
AdLucem's Avatar
Default 8k & clutch failed...dual mass flywheel?
I,m seriously physically ill. I put a clutch kit(OEM/Luk). in my a6 2.7t about 8k miles ago & just crapped out.
I bought the car in Jan 06', it had 62k miles. I drove it for about 1k & the clutch plate came apart...of course, I blamed it
on the previous owner.
I thought that way too soon & had to be due to driving habits. (I had a BMW 86' 635csi 5spd 125k - 225k & never replaced
or had any clutch issues). Anyway....
I worked as a BMW tech for a number of years so I went ahead & did the job myself, it was a quite an experience under
jackstands. It went well though & the car seemed to be fine until last night. What the hell? Could it be the flywheel? All I
checked was the surface & was fine. Is it a dual mass fw? Would that be a probable cause? Any techs see this problem
before? Any insight will be greatly appreciated.
Old Dec 9, 2006 | 10:23 PM
dankhound's Avatar
Default RE: 8k & clutch failed...dual mass flywheel?
Never seen anything like that. How did the splines on the input shaft look? Maybe the clutch disks are haning up on the input shaft. I cant imagine anything with the flywheel could cause that quick of a failure unless there was some visable damage to the flywheel, like a groove or something. Did you replace the pressure plate and throwout bearing as well? If not it could be the cause. The only other thing i could think of is the master or slave hanging up, but ive never seen either of those fail in that manner before.
Old Dec 29, 2007 | 10:19 AM
AdLucem's Avatar
hah, this is way over due, I havent visited the forum in a long time & I though I'd follow up......It was the dual mass FW. The internal springs were ruined, it had zero rebound, I replaced it with an aluminum single mass Fidanza ($325 & a beautiful piece) an RS4 pressure plate, disc, T/O & pilot bearings. While I was in it I ported the exhaust manifolds, gutted the pre-cats, rebuilt the turbos, changed the timing belt, replaced the cam seals, valve cover gaskets & other small maintenance items. I had to have the 6 spd tranny rebuilt, I'm attributing it to the flywheel. $3,000.00 worth of synchros & gears were ruined. Its a different animal now.
Cobain66
May 22, 2009 10:38 AM
Tai
Mar 10, 2009 12:34 PM
tdn
Jan 9, 2008 08:31 PM
quattrosedan
Dec 19, 2006 11:54 AM
Doss
Oct 9, 2006 08:30 PM
