'96 A4 randomly died and wont restart, no codes, please help!
Old Dec 19, 2006 | 04:10 AM
maxaud's Avatar
Default '96 A4 randomly died and wont restart, no codes, please help!
Hello everyone, new to the board. the Audi A4 that I'm having a problem with isn't mine, but a close friends. It randomly died turning a corner today and It started up and ran for a few seconds and then shut off again. We tow'd it to my house and once there it started but ran real rough around 200rpms, trying to run. I can't seem to find where the relays are located at and I'm totally new to the Audi world. I check for codes and it didn't find any. The In2 light is flashing but it's been doing that for over 1500 miles. we unhook'd the battery for 10-15 minutes and then rehook'd it and it started up and ran fine for about 5-6 seconds and then shut off again and couldn't restart. We then check'd to see if there was any spark and we found there to be none... I then check the fuel pressure by unhooking a fuel line and turning the car over and none came out. Is there a EFI relay that may have gone bad for niether the spark or fuel pump not to work properly or at wierd/random times? any help would be greatly appreciated. thanks for the time.
Dustin
Old Dec 19, 2006 | 12:48 PM
rayveedub's Avatar
Default RE: '96 A4 randomly died and wont restart, no codes, please help!
you sound like you know a little something about cars so ill ask this, did you listen for the fuel pump? if the pump is running then look at coilpacks, this is a common problem with these cars.
Old Dec 19, 2006 | 05:11 PM
maxaud's Avatar
well, having no fuel coming through the lines leads me to believe that it's not working. The only thing that makes a noise when the key is turn'd to the on positionis a shiny metal box under the hood on the drivers side with vacuum lines coming off of it. Is there an EFI fus/relay located somewhere? where are the relays located at on this car? I can't seem to find them anywhere.
Old Dec 19, 2006 | 05:28 PM
techbod's Avatar
check engine to chassis ground wire for good contact and condition of the wire
[IMG]local://upfiles/12092/B5951AB0D04540E1A085628111A93353.jpg[/IMG]
[IMG]local://upfiles/12092/68CF5AF8896842259F8C8CFCA8E3EA97.jpg[/IMG]
Old Dec 19, 2006 | 05:43 PM
maxaud's Avatar
thanks for the relay locations. I'm guessing that it's the same spot for the LHD version? What one is the EFI relay? thanks much.
Nashy22
Jun 16, 2014 04:36 PM
flyboyx
Jan 8, 2010 12:28 PM
Matt m
Dec 9, 2008 11:51 PM
ezlnh8u
Sep 21, 2007 02:49 PM
hopskid
Apr 23, 2006 04:06 AM
