'97 A6 wagon - sunroof won't close
Old Mar 10, 2009 | 11:14 AM
mikeod's Avatar
Default '97 A6 wagon - sunroof won't close
So I had to jump start my car the other day cause the battery died. When I turned the ignition, the sunroof opened and has not been able to close. It's been 3 days now. I google'd and saw that there is an allan-key manual crank under a panel in front of the sunroof. I found it, but it will absolutely NOT budge. I can't even turn the key at all. I have tried pulling the sunroof shut manually with no luck. What's going on?
Old Mar 10, 2009 | 12:31 PM
beefski's Avatar
Had a similar issue w my 96. Turn the sunroof switch to the closed position, thed disconect the battery cable then re attach it. It should close. I was going through this daily as I had a bad battery that would not hold a charge.
HJ Matroni
Jul 19, 2013 07:20 PM
CRuby
May 30, 2013 04:54 PM
Doo
Apr 15, 2011 01:41 PM
Sanjoy
Feb 14, 2011 09:05 PM
jasonrann
Dec 9, 2006 04:12 PM
