a4 1.8t quattro 1997
Old Nov 4, 2007 | 06:18 PM
gaulin99's Avatar
Default a4 1.8t quattro 1997
Hi,
I redlined my a4 because of slack mode...when it happened something got loud with the exhaust.
there's a pipe on the passenger side in between the engine and the air filter that blew off its attachment point.I can easily reach it from the top of the engine compartment.
Anyone know what this is?
I have to get it to the shop and am also wondering if I can drive it there or will i ruin something?
Thanks,
JG
Old Nov 4, 2007 | 07:44 PM
tHe kNiGHt FaLL's Avatar
Default RE: a4 1.8t quattro 1997
whats slack mode...?
i dunno what your really refering to... could be boost bypass... or pcv...
i'm not gonna make a judgement on its stability w/o knowing more information about exactly wha it is
Old Nov 4, 2007 | 08:22 PM
gaulin99's Avatar
Hi,
it looks like exhaust pipe (metal) i think its near the turbo? in the engine compartment.
hot air blow into it
Old Nov 4, 2007 | 08:25 PM
gaulin99's Avatar
i may not be using the correct word for slack
all the selectors for the shift are lit up at once and tranny dont work right.no reverse unless i cancel codes the after putting in forward gears reverse will be gone untill i reset codes again with vagcom
Old Nov 4, 2007 | 08:46 PM
ORIGINAL: gaulin99
you have to do this everytime you run the car...?
and which engine are we talking about...? it sounds like an air pump or something other than which i intially listed
Old Nov 4, 2007 | 08:50 PM
gaulin99's Avatar
1997 a4 1.8t quattro
yah I have to do the code reader thing evertime
Old Nov 4, 2007 | 08:58 PM
looks like something w/ the secondary air system.
and i'd be more concerned w/ your trans issues... cause thats bad.
Old Nov 10, 2007 | 11:41 AM
dankhound's Avatar
Yuou probably have a broken catalytic converter near the turbo.
tims97a4
Aug 8, 2012 07:48 AM
nzant008
Feb 16, 2011 05:24 PM
jorjasa
Jun 21, 2010 11:46 PM
DubSeelVR6
May 15, 2007 12:34 AM
cdenney1
Feb 20, 2005 07:53 PM
