A4 B5 1998 Eurosport Ecodes Installed - Driver Light No Power - Ballast Silent - Help
Old Aug 13, 2012 | 06:43 PM
xburbx's Avatar
Default A4 B5 1998 Eurosport Ecodes Installed - Driver Light No Power - Ballast Silent - Help
So I ordered eurosport ecodes 2 piece. I installed them and they worked fine at first. Then the passenger side would only stay on for 2 minutes and then turn off. It was the ballast and the company sent me a new one. That was fine. The lights worked for 2 weeks and now the driver side one won't turn on. They recommended the anti-flicker device. I installed those. Only the passenger side still works and the driver side does not turn on. I turned the car on and went to listen for the ballast. The drivers side ballast does not make noise. I swapped the ballasts and the drivers side worked on the passenger side. I checked the fuses and 18,19,20, 21 are all fine.
The bottom line is that there was power and now does not appear to be power to the driver headlight. I checked the connector pin to the headlight and it looks fine as far as I can tell.
Any ideas?
aberabee
Sep 4, 2009 11:41 AM
Andyid
Jul 23, 2009 06:55 AM
dixter
Oct 14, 2006 08:38 PM
dixter
Jul 11, 2006 12:11 AM
Yuikio
Apr 12, 2005 07:21 PM
