A4 B5 2.8 auto - transmission fluid brands, specs, sources, quantity
I am installing a new/used transmission and need to put in trans fluid:
What type is recommended?
What brands are recommended, or 'any'?
What quantity is required?
I picked up a new/used (78k miles) transmission yesterday.
Before installing the trans, is there anything I should do to it?
Once installed, would you drop the pan, check fluid and change filter, then top of the fluid?
(What parts are needed? Trans pan gasket, filter, fluid)?
